When I encode NTSC DV to 352 X 240 MPEG 1, I always get a "green flash", a green screen that "depixellates" in a second or two to normal video. At first I thought is was something to do with TMPGEnc, but it does it with the CCE SP as well.
Any idea what is causing this? Is it because I'm going from 720 X 480 to 352 X 240 and the proportions are not correct?
I've never seen this happen. Are you trying to do this in real time? If so it probably means the CPU is pegged trying to deinterlace and downscale.
I run DV off a cable box through a Canopus ADVC and routinely realtime encode to VCD or DVD MPeg2. DVD Mpeg2 takes a fast processor. -
It only happens when I go from DV to MPEG 1 at 352 X 240(making video clips for web use). If I use one of TMPGEnc VCD templates, it doesn't happen, that's why I thought I might have some of the size settings wrong. Cranks out high quality, multiple pass VBR MPEG 2 files, no problem. I'm still learning the many aspects of MPEG encoding, so operator error is always a real possibility.
I doubt if the CPU is maxxed out. The 3.4C does much tougher encoding jobs than short MPEG 1 clips. I'll have to check out the interlacing settings.
Green pixels all over - HELP
By ski in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 15:04 -
Could I use a green fabric as a green screen? Where could I get fabric?
By bojadada in forum Off topicReplies: 2Last Post: 5th Dec 2009, 12:48 -
my video has too much green
By babygodzilla in forum Newbie / General discussionsReplies: 12Last Post: 8th Sep 2008, 20:08 -
green picture!
By w50cfc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jun 2007, 03:39
