Hi,
I'm just about ready to burn. I'm doing a test with X3. Ultimately, I will burn a dual-layer back-up (no, just the movie does not fit on a single-layer, and I want to b/u extras too).
I used VOB Blanker to get rid of all the crap. So I have all the video files in a folder on my hard drive.
What I'm wondering is, is it better to burn using the video files directly to the media, or to create an ISO on your hard drive, then burn that? Does one result in better quality or more stable results than the other?
Also, I found a guide showing how to burn dvd files directly to dual-layer, but how do you do that with single layer in ImgBurn? (Of course, if doing an ISO is better, then that question is moot, but I'd still like to know...)
Thanks for the help!
Results 1 to 13 of 13
It shouldn't matter. It definitely won't change the audio or video quality. The only real advantage of ISO over files IMHO is when you are burning DL because the correct layer break position is so important. I still just burn the files in Nero if doing SL but for DL I use the PGCEdit/IMGBurn method.Originally Posted by bloomcountyIf in doubt, Google it.
Pretty much the same way, using "Build" mode. You just don't have to deal with any of the layer-break stuff (obviously).Originally Posted by bloomcounty
Once you've loaded the proper directory, just press the "Build" button. Easy.
Build mode specific guide:
http://forum.imgburn.com/index.php?showtopic=1779
Jim -
Thanks for the posts!
Okay, so when I'm burning dual-layer, I should use ImgBurn to create an ISO on my hard drive, then burn the ISO image to the dual-layer media also with ImgBurn. Is that correct?
If it's single layer, then if I've got video files, there's really no reason to create an ISO first, just let ImgBurn do a burn directly to the single-layer media per the guide that's linked above in Jim44's post. Correct?
Just want to make sure I'm understanding...
So, with all that in mind, what's the use of the option to create an ISO for a single-layer burn?
Thanks! -
Maybe you don't have a burner! ISO images (of any size) can always be mounted via emulation software (Deamon Tools) for later installation/game play/etc. Or how about archiving multiple SL ISO images onto a DL disk??
Trev -
Whether you are burning Dual or Single layer, you can do it either way -- create the ISO Image, then burn the image. Or just burn the DVD Folders directly to disc...
Regards,
George -
bloomcounty,
As GeorgeW mentioned, the latest version of ImgBurn lets you proview the layer break choices before choosing one, so unless you have some specific purpose in mind that requires creating an ISO, there's no longer any need to make one for single layer or dual layer burns. -
I agree! except I've had a few backups not play properly on certain movies , so I'll create an ISO and burn that with success....Also you may give DVDRB a try, it gives an option to backup main movie+extras= DVD-5. I have it and it works, trust me!!!!!!Originally Posted by jimmalenko" Who needs Google, my wife knows everything"
Here's another guide specific to burning DL video_ts files straight to disc.
http://forum.imgburn.com/index.php?showtopic=1780
Use the same method for SL discs, only difference, you won't have to deal with the layer break stuff.
If you have the video_ts files on your hard drive already, you do not have to create an ISO first, it just adds another unnecessary step, your layer break will not be affected. This applies to both SL and DL. -
does anybody know how i copy DVD ontom hard drive then play back on laptop from hard drive.
OS Vista
How to use ImgBurn to burn mkv files in DVD
By carlmart in forum Video ConversionReplies: 3Last Post: 30th Sep 2011, 22:09 -
Help me create an .iso file from .vob dvd files!!
By SlyOne in forum DVD RippingReplies: 2Last Post: 15th Aug 2010, 10:25 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 03:12 -
how to correctly burn iso that FAVC makes using ImgBurn
By brentonboy in forum Newbie / General discussionsReplies: 8Last Post: 19th Dec 2007, 16:54 -
Playing ISO and VOB files directly to TV
By indiraider in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Oct 2007, 01:29
