When I play an avi file, I hear only this clicking sound instead of the actual audio. The original file's audio is PCM. I opened the file with AVIcodec and got:
Audio : 19.55 MB, 176 Kbps, 11025 Hz, 2 channels, 0x1 = PCM, Supported.
The entire file is a little over 103 MB. Is the audio corrupt? Is there any way to restore it to the intended audio track?
I included a clip of the sound below.
audio.wav
Sounds pretty messed up. You can try this:
https://forum.videohelp.com/viewtopic.php?t=321684 -
Thank you for such a quick reply. I downloaded the zip files and repaired the file, but the audio still has that same clicking sound
Is there anything else I can do?
Garbled sound in DV avi file
By BlueShaman in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2010, 10:05 -
problem with sound in .avi file
By mattwilsoni in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2010, 12:06 -
There is clicking and shuffling sound in my audio
By shashgo in forum AudioReplies: 11Last Post: 9th Dec 2008, 20:05 -
Question about Windows error msg and high cpu when right clicking on avi
By jimdagys in forum ComputerReplies: 3Last Post: 4th May 2008, 18:01 -
Problems When Clicking on an .avi File
By ATAZ in forum ComputerReplies: 5Last Post: 10th Mar 2008, 20:50
