Hi All,
I've got a Panasonic DMR-EX75 which can upscale to 1080i via a HDMI port and a Wharfedale LCD26HD than can play 1080i via the DVI port.
So therefore i assume i can play standard dvd's at 1080i?
To begin with i got a HDMI to HDMI cable by mistake, so i bought a HDMI to DVI connector, and both TV and DVD recognised the cable was attached. However the Panasonic wouldn't let me change the settings in HDMI setup, everything apart from automatic was greyed out so i couldn't select 1080i.
So i then ordered a HDMI to DVI lead and when this is plugged in neither recognise it's attached.
Do i need a specific type of cable to get 1080i? there seems to be many kinds and a big price difference between certain cables.
Any help would be grately appreciated.
Closed Thread
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
analog upconverting
By jaybird in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2010, 22:20 -
HD and upconverting over component?
By RoyGBiv-inRI in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Jul 2009, 20:40 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 17:25 -
1080i Upconverting DVD Player Through Component Inputs
By Teutatis in forum DVD & Blu-ray PlayersReplies: 5Last Post: 16th May 2007, 01:16
