I have some mpeg files that I recorded by MythTV. I want to make DVD from it and preserve the subtitle. I used TMPEGEnc MPEG editor to cut out some unwanted parts and then use DVD-lab pro for authorizing. What tool can I use to rip the subtitle so that I can add it during authoring? Thanks in advance.
If it is really closed caption (line21 data), ProjectX will not help you, as it supports the European standard ('teletext') but not the NTSC equivalent (Line 21 Closed Captions). You may find the necessary tools and information for Line 21 Closed Captions here:
http://www.geocities.com/mcpoodle43/SCC_TOOLS/DOCS/SCC_TOOLS.HTML#capture_analogGUI for dvdauthor:
https://www.videohelp.com/~gfd/
Rip DVD to AVI / Mpeg BUt Retaining File Names?
By tomkat2010 in forum Video ConversionReplies: 1Last Post: 29th Feb 2012, 04:15 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 17:38 -
Mux raw subtitle streams in a existing mpeg file.
By etvideob in forum LinuxReplies: 0Last Post: 14th Aug 2009, 02:22 -
mpeg file subtitle timing problem
By ecc in forum SubtitleReplies: 5Last Post: 25th Jun 2007, 07:07
