Hi
I've been noticing a strange problem with SimpleDivx. When I set up a batch job, some of the files don't come out as expected. For instance, the other night, I set up all 6 episodes of the 1st series of I'm Alan Partridge to convert as 6 different Avi files. I prevewed each one prior to conversion, and they all started okay.
However upon viewing the results, both Episodes 3 and 4 begin about 3 minutes into the programme. I can't think why this would be, unless the actual structure of the files on the DVD places one episode across 2 tracks. I don't think this can be the case as the preview worked fine.
So 4 of the episodes are about 24 minutes long, and 2 of them are about 21 minutes long. It seams to cut in after a fade out, so I also wondering whether the 'Fade in/out' option isn't behaving itself (which I haven't got activated)
Any help would be great - thanks!!
SimpleDivX, and cropping/resizing
By snafubaby in forum DVD RippingReplies: 2Last Post: 21st Dec 2008, 16:39 -
Is SimpleDivx (Mencoder) multithreaded)...which encoders are?
By radium02 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 02:28 -
Does SimpleDivX install its own versions of codecs?
By Toastie in forum DVD RippingReplies: 0Last Post: 1st Sep 2007, 15:23 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57 -
SimpleDivX replacement
By alan79 in forum DVD RippingReplies: 3Last Post: 18th May 2007, 11:34
