What can I do with this kind of format to make it into a PAL DVD. I can't even insert it in Ulead DVD Workshop 2.Format : MPEG-4 Generic / MPEG-4
Family : MPEG-4
File size : 847 MiB
PlayTime : 1h 21mn
Bit rate : 1445 Kbps
Video #0
Codec : MPEG-4 Video
Info : (MPEG-4) Apple MPEG-4 Video
PlayTime : 1h 21mn
Bit rate : 1357 Kbps
Width : 560
Height : 432
Aspect ratio : 4/3
Frame rate : 29.97 fps
Bits/(Pixel*Frame) : 0.187
Audio #0
Codec : AAC LC
PlayTime : 1h 21mn
Bit rate : 81 Kbps
Channel(s) : 2 channels
Sampling rate : 44 KHz
StreamSize : 49540864
ConvertXtoDVD if you are looking for an easy all-in-one solution.
You could also use Super and convert to dvd mpeg2 that you can import in Ulead DVD Workshop. -
You need quicktime installed most likely .
Ulead video studio 9 supports mov input ... but I dont think ulead dvd workshop 2 dose .
You may also want to try super to convert it to mpeg2 with ac3 (small and compact) , or pcm wav (very large) audio ... vob output seem's not to work properly .
The grab batchdemux from the site of dvdauthogui to demux the mpeg2 .
If the audio is not acceptable , and it's exention is m2a , rename the exetension to mpa ... and use besweet to convert it to a format that is acceptable by your product .
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 20:46 -
trouble with audio after appending a .jpg turned .mp4 to another .mp4
By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 10:55 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53 -
loop mp4 or avi locally so will play on mp4 player - ?
By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 21:24 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 22:24
