Can anyone recommend me a good free capturing tool. I really like and use AMCAP (https://www.videohelp.com/tools?tool=AMcap) But it is shareware(Demo). And I hate the software of my webcam. Are there any other free webcam capturing tools?
Results 1 to 9 of 9
Virtualdub should do the job
http://www.kiva.org/about -
There's an older Amcap (2.72 - fully functional) available from the
BTWincap driver site.
http://prdownloads.sourceforge.net/btwincap/wdmmiscutils2.73.zip?download -
I like Virtual VCR. I switched to that a few years ago and have never looked back. I personally like how you can save and load profiles since I often capture in both PAL and NTSC.
Darryl -
zoobie: USB Devices wont work with those tools.
edDV: I have virtualdub. How do i setup my webcam with it? looks complicated.
deckard8: Thanks
I used to take stills with "Enter" Key. How do i take one with that version?
webcams are usually "video for windows" uncompressed at low resolutions and low framerates. They usually need a driver for control. Once the driver is installed, the webcam will show under capture devices and the controls show under preferences
Captureflux is excellent with most webcams, and has many features like taking snapshots, scheduling the capture, inlaying the date.
Paul Glagla
http://paul.glagla.free.fr/index_en.htm -
If you just want the lightweight fullscreen view the program offers I didn't find these tools satisfying, but this open source modification does that http://code.google.com/p/amcap/.
A lightweight fullscreen webcam viewer with full resolution and fps configuration was surprisingly difficult to find, but this program does that.
Amcap (using Ezcap hardware) pixelation issues.
By Joesavage1 in forum Capturing and VCRReplies: 1Last Post: 5th May 2011, 12:51 -
Just updated to IE8 now,Musicmatch jukebox no longer works. Free Alternate
By Denvers Dawgs in forum ComputerReplies: 51Last Post: 11th Feb 2010, 15:52 -
Alternate format other than DV.
By cowmix in forum Capturing and VCRReplies: 13Last Post: 14th Sep 2009, 22:21 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 13:16 -
AMcap codes
By suefyzah in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2008, 00:37
