i have captured in mpeg4 , as this is the smallest size i can make with my capture card , now with what softwrae i can edit the clips kindly help me....
bye
sohail gagai
Depends what you mean by mpeg4.
ASP MPEG-4 in an mp4 container?
lossless AVC in an mp4 container?
MS MPEG-4 in an asf container?
Xvid/mp3 in an avi container? -
I generally avoid editing in any highly compressed video format. If you need to do extensive editing, it can difficult to get clean cuts and pastes. Other formats that are less compressed like HuffyUV or DV are better choices.
But for editng MPEG-4 type files, VirtualDub is always a good place to start. -
Apparently the latest virtualdub (1.7.1 ?) can do smart editing of some mpeg-4 formats, whereas the earlier versions were limited to key-frame only edits unless you were happy to re-encode the lot.
Read my blog here.
No reason why you can't encode I frame only MPEG-4. AVC also allows for lossless encoding where it wouldn't matter.
Which software to edit dreambox mpeg4 ts?
By manutd in forum EditingReplies: 11Last Post: 3rd Jan 2012, 08:00 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 07:01 -
HOW TO EDIT MPEG4 FILES IN (DIVX).AVI, .mkv and .mp4 Containers
By jhb50 in forum User guidesReplies: 0Last Post: 18th Jul 2009, 22:32 -
What is the best way to edit MPEG4 files
By Paul W in forum Newbie / General discussionsReplies: 8Last Post: 1st Apr 2008, 11:32 -
edit w/o recompressing mpeg4 and wmv
By mrready in forum EditingReplies: 3Last Post: 29th Jan 2008, 08:56
