After I installed Windows Vista (full install after formatting my HD) my DVDDecrypter pops up the following message before exiting (Failed to set data for "DVDDecrypterPlayDVDMovieOnArrival") Not a big deal because I can hit the exit "x" and get out of the program but what does this message mean and how do I get rid of it??
Results 1 to 9 of 9
Try setting compatibility mode to Windows XP for DVD Decrypter and see if a) the message goes away, and b) the program runs.
Read my blog here.
That didn't seem to help, it still does the same thing on exit. Here is the log it produced if it makes any sense to you:
I 16:39:38 DVD Decrypter Version 3.5.4.0 started!
I 16:39:38 Microsoft Windows 98
I 16:39:38 Initialising ASPI...
E 16:39:38 Unable to initialise ASPI! - WNASPI32.DLL
E 16:39:38 Reason: The specified module could not be found.
E 16:39:38 You need to install an ASPI manager.
E 16:39:38 Visit http://www.dvddecrypter.com to download one.
E 16:39:38 Alternatively, try changing the 'I/O Interface' in the Settings to a different one.
I must be missing the WNASP132.DLL driver. I am a little reluctant to install one because Vista is a pain about drivers it doesn't recognize. Installing Alcohol 120% for instance caused me to have to re-format and reinstall all my programs from scratch. Don't want that to happen again. -
Hmm, someone with Vista might be able to help. The Vista compatibility list below says DVDDecrypter should work:
http://www.iexbeta.com/wiki/index.php/Windows_Vista_Software_Compatibility_List
Out of curiosity I'm gunna poke around some more, maybe I'll find something. Good luck.Pull! Bang! Darn! -
I think I found an answer for you. Scroll down to r0lz' explanation:
http://forum.digital-digest.com/showthread.php?p=508087Pull! Bang! Darn! -
I had all kinds of error messages on vista with decrypter until I disabled the user control on my account. Now I have no problems. Decrypter dosn't seem to be buffering but My disks all turn out fine. To disable user control click start/run type in msconfig.ext, click on tools, and disable uac.. you will have to reboot. I guess it has something to do with vista security. I am not running decrypter in compatibility mode either. Hope this helps
OK smokies430, here are the solution, right click the DVDDecrypter icon on the desktop and click property, down in the botton click advance, and click run as administrator, (you no need to check the run compatibility)
go to start, control panel and click user accounts, click in turn User Accounts Control on or off, and turn user account control off, you can open Decrypter and close with not problem.
Amatheu
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Nero Error Msg - 'Prepare Session Failed'
By Dieseldog in forum Authoring (DVD)Replies: 0Last Post: 19th Dec 2011, 06:38 -
Question about Windows error msg and high cpu when right clicking on avi
By jimdagys in forum ComputerReplies: 3Last Post: 4th May 2008, 17:01 -
error msg when try to record on drw-500
By harryb in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 23:57 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 11:42
