Hi,
I'm having some weird issues with mpeg1 encoding...
I have ffmpeg installed on an ArchLinux box and when i try simple command to convert a VOB file(that has been split by DVD shrink-according to chapter)...it doesnt work properly
Here is the problem:
I can open the file in windows media player when the file is on my machine
I get problems when i serve the .mpg file online:
I can open link with Firefox properly
When i open the page with Internet Explorer and click on the link...windows media player loads the file..but only detects it as a 3 second movie..instead of 20 minutes!
here is the command i've used:
ffmpeg -i 1.VOB -b 800K -deinterlace -ab 56 -ar 22050 -aspect 4:3 output.mpg
I've also tried using -vcodec mpegvideo ..no dice
Here are the characteristics of the encoded output file:
Video: MPEG1 Video 320x240 29.97fps 104857Kbps [Video]
Audio: MPEG Audio 44100Hz stereo 64Kbps [Audio]
I'm not sure why it keeps setting video bitrate to 104857k...when i can clearly see its encoding at 800k in ffmpeg's progress!
when i tried loading this output.mpg file in VirtualDub, I get this message:
"MPEG: Anachronistic or discontinuous timestamp found in video stream 0 at byte position 2062183, from 1814696 to 52612515. This may indicate an improper join."
anyone else encounter this problem?
please help
Results 1 to 1 of 1
libfaac encoding with ffmpeg
By chicken264 in forum Video ConversionReplies: 31Last Post: 20th Dec 2012, 09:04 -
[FFmpeg] Problems encoding a MOV
By Klagar in forum Video ConversionReplies: 0Last Post: 29th Apr 2011, 12:18 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Encoding .DV problems with ffmpeg (e.g. MPEG4 -> DV or VOB -> DV)
By AlphaMonk in forum ffmpegX general discussionReplies: 1Last Post: 23rd Feb 2010, 05:24 -
ffmpeg encoding help
By guitarscn in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2008, 17:11
