Hi,
I'm looking for a program (free if possible) that can detect all scenes changes in a mpeg-2 file.
If possible it would be great if the program can detect "cuts" from a video shooted with a camcorder (analog on vhs tape captured on a dvd-r).
I seen Comskip but it seems it's only for commercial
Do you have some suggestions ?
Thanks.
Comskip looks primarily for fades which signify commercial breaks, but could be used for other scene detection. Scenealyzer Live works for DV, even if the source is analogue based (i.e. it isn't limited to time code based scene detection).
I don't know of any that work across multi-formats.Read my blog here.
I'm impressed with the scene detection tool in MPEG Video Wizard. Like any other scene detection tool I've seen, there are many false scene detections, but it does not seem to miss any either. Takes around 8 minutes for a 2 hour clip. Not totally free, but fully functional free trial for 30 days.
To use, drage clip to input monitor, press F3, then click "Scene" in the "Bookmarks" window. -
Comskip runs on my 1.6GHz laptop at more then 400fps on a 5MBit/s VBR SD recordings with all detection methods enable.
Make sure your recording is not on a nearly full or fragmented disk.
Comskip does require some memory so ensure your system does not to start swap memory to the disk during processing (e.g. there must be at least 100kByte free memory when comskip runs.)
W.r.t scene change detection. The VideoRedo output file includes standard the scene change list
It can be used to quickly navigate inside the recording and for generating DVD chapter information
Detect Scene Change in x264
By Anakin in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2012, 19:31 -
How does one detect fake images?
By mysts in forum Off topicReplies: 8Last Post: 29th Sep 2011, 23:16 -
ffmpeg motion detect
By xento in forum ffmpegX general discussionReplies: 0Last Post: 31st Aug 2011, 15:27 -
PC can not detect Dv recorder
By dazedandamused in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Apr 2009, 18:45 -
Detect scene changes in Avisynth?
By AlanHK in forum EditingReplies: 0Last Post: 12th Aug 2007, 06:12
