Hello every1,
i got the d-vision standalone dvd player 310-dvx. but now i cant play some dvd's ..
it says: seq play and than it stops..
i found this hack on the site, but i cant get to it .. the "tray" where do i find it ..
is that the picture says: DVD player totally blue? because when i type: 9735 he always says: no disc...
after i pressed all the numbers i dont get a menu to set the regions.. so my question is .. does some1 know, what to do?
the main problem is the seq play, not the region set.. i only think i can find the solution there..
this is the hack i've found:
Region code hack posted by Martijn, December 28 2006:
Open tray
Press code 9735 on remote controll
Here you can set your region (0 = region free)
thanks for all the replies.
Results 1 to 1 of 1
Terminator Vision
By Squid_uk in forum EditingReplies: 16Last Post: 17th May 2009, 15:57 -
Hi-Den Vision HDMI 1080p Digital Media Player
By minidv2dvd in forum Media Center PC / MediaCentersReplies: 0Last Post: 11th May 2009, 12:09 -
Magnavox NB500MG9 (walmart) BD player..Nero vision..BD on DVDR working?
By markm75 in forum Authoring (Blu-ray)Replies: 8Last Post: 1st Dec 2008, 03:11 -
Nero Vision 5 Help
By luckyboym in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 01:47 -
Nero Vision 5
By marioval in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 14:45
