I think that I should know how to do this correctly but I seem to be running into a mental block:
I have a 2minute video clip that I need to raise the volume of the audio quite a bit.
I have tried to use Womble VCR to demux the streams and then use it's audio editor to save out with a volume increase. the +12db it offers is fine and seems to work in preview but when I remux it the volume is the same as it was.
Super works to convert the mpg2 to mpg2 and increase the volume, the quality of the video suffers little for my purpose but the program truncates 45 seconds from the whole clip (grrr).
Nero Wave editor won't import the .mpa audio file. Which I thought I would then remux with womble.
Any suggestions?
Quicker is better as I have several clips to adjust.
Thanks.
--dES
"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Never mind I answered my own question.
I was trying to use Nero Wave Editor (which I kind of like) to adjust volume, I forgot that I have Audacity installed and that is able to import the .mpa file from Womble. From there I made my changes in Audacity, resaved as .mp2 and used Womble to remux and resave again.
More steps than I would like but quick and effective.
Thanks for reading.
--dES"You can observe a lot by watching." - Yogi Bera
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
Premiere Pro on OSX - mpeg2 clip audio missing
By Mylo in forum EditingReplies: 2Last Post: 17th Feb 2011, 06:00 -
[SOLVED] WMV to MPEG4/AVI/anything else has increasing audio desynch.
By Eilonwy05 in forum Video ConversionReplies: 13Last Post: 15th Jun 2008, 14:01 -
Increasing voices in 6ch audio
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 16:21 -
how can I create mpeg2-TS clip composed of one (only one!!!) black frame?
By mb508 in forum EditingReplies: 3Last Post: 4th Jul 2007, 15:04
