I have been recording TV programmes on my Panasonic DVD recorder using a RAM disk and then use TMPGEnc to make a -R DVD which I have done many times successfully. I live in the UK and I have sent a friend in the USA disk's which she has attempted to play on her new PAL compatible player which she say she got from Seer's. She says some play and some don't. I may have sent her one or two -R disks than I made directly on my Panasonic recorder but I am sure I finalised them. Are the recordings on my Panasonic and from TMPGEnc region free and if so any body got any ideas why they are not playing.
Results 1 to 13 of 13
As far as I know all DVD Recorders are region free (at least all mine have been).
I had a similar problem in that disks recorded on the recorder would not play in the player. After much agro I tracked this down to either book type or Media. My player will only play DVD-ROM disks (probably due to its age)
My best guess from what you say is that your friends DVD player is not abe to play DVD-R disks. Try setting the Booktype to DVD-ROM -
The discs that DVD Recorder actually record are region free, however the player component may not be.
That some play and some don't at least tells you her player is PAL capable, so it leaves either recording method or media as the culprit.
Unless she sends the non-working ones back to you, the best you can do going forward is to test each disc before you send it over.Read my blog here.
In this case, since some discs play and some don't, it can't be that the player isn't able to play DVD-R discs. It is most likely a media problem as guns1nger suggests. Perhaps the discs are different brands and while you might think "All brands are the same", her DVD player may operate differently. My old Apex DVD player was incredibly fussy about DVD+R media brands, but it played every DVD-R brand I tried on it. It's not unheard of for players, especially older ones, to have problems with DVD-R brands, DVD+R brands, or both. By the way, "book type" which IKnowNothing mentions only applies to DVD+R discs, so that's not an issue here. If you are dealing with dual layer media and you neglected to mention that, that is a whole other set of problems. I am very very unimpressed with DVD-R DL discs and am glad I only bought 3 of them. DVD-R DL have layer break issues that +R DL discs don't have. This may not at all be the issue for you, but I mention this only because people here on the forums have a really bad habit of neglecting to mention all the facts about their problem because they think that something isn't important, when in fact it is exactly the cause of their problem. If you are not using DL media and your brand is the same on all discs, it could be that you are using low quality media (look at http://www.nomoreocasters.com for more info on media quality) and some discs have problems or that something strange is happening in the copy process to DVD-R that is causing the problem.
By the way, the store is "Sears" not "Seers", but you had no way of knowing that since you don't live in the USA. -
Thanks for all your replies. The disks were all single layer Maxell -R. I did test them on my Panasonic DMR-ES10 recorder before I sent them so maybe its because her player will not play -R although its new and she said its supposed to play everything??
I bow to Jman98's greater knowledge aboutbook type - however
my experience was that of a spindle of100 single Layer DVD-Rs those burnt with the book type set to DVD-R would not play in my player (a Cyberhome) whilst those burnt with it set to DVD-ROM did. (The only difference in the Nero 6 settings was Book Type or at least that's all I changed to correct the problem)
ALL of the disks play in the recorder and on the PC so I know they are not coasters. -
What is the overall running time of the discs which stopped playing?
I would say 3.5 - 4 hours. I usually record on LP on my Panasonic. I will try and find out what the make of the player is.
Recordings over 3 hours made on a Panasonic DMR often freeze on my Pioneer standalone. I have turn the power off then back on again to resume play.
Does anyone else think this be a reason why My recordings would not play on a US PAL compatible player. Maybe I was trying to cram too much onto the disk.
Region Free DVD Player Question
By notridgid in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th Dec 2010, 17:57 -
DVD multi-region player question...
By mjl1297 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2010, 05:05 -
setting region with AVS and a Nero question
By Willy Bee in forum Authoring (DVD)Replies: 2Last Post: 21st Feb 2010, 22:21 -
DVD Decrypter Region Question
By nickolasj80 in forum DVD RippingReplies: 2Last Post: 21st Jun 2007, 19:26 -
Question: Region Free DVD Players
By SentaiFan in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th May 2007, 03:07
