anybody have any experience with this TV
http://shop4.outpost.com/product/5101336;jsessionid=IW1piFV+ITp8iYnP2rG-mw**.node2?sit...H:MAIN_RSLT_PG
I will have to buy an HD tuner separate, at a later date, my primary interest will be in playing back DVDs since i usually buy the wide screen version, BUT only have a standard TV at the moment
the specs seem pretty impressive for the price
				Results 1 to 17 of 17
	I suggest you look at one in the store before you buy. The specs look good but the one I saw at Fry's looked soft next to a similar size Panasonic LCD ($899).
 The source was their distributed off air feed. It might look better with a progressive DVD source. This model isn't that good with interlace SD sources.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	thanks ed, i'm going to 'look around' the store and compare them, this gives me something to watch for,
 most TV's have controls for contrast , sharpness etc...
 have you ever been in a store where the big ticket items where set to their best ,and the less expensive models where set at soft settings, to make them less attractive
 OR even vise-versa to push the model they wanted to clear out
 do they even have the remotes out so , we can play with the settings
	They know all the tricks but I have to say this model didn't match the double price Panasonic sitting next to it for 480i/1080i source. I think I was seeing 480i upscaled to 1080i at the time. It might be fine for progressive DVD. Try to find a retailer that will let you play your test DVD.Originally Posted by theewizard
	office depot has the '32' inch version 432v with HDTV-ASTC tuner for $549 normally $699, grand opening sale
 I need to get out to the stores and do some looking
	went to 'office depot' today to see the 32" olivea ALL sold out.
 but they had this 32" ( 31.5 screen visible ) Vewsonic HDTV ASTC tuner sitting there $549 after rebates ( i hate dealing with rebates ) this thing has beautiful color, even though the specs say the contrast ratio is 800:1, the olevia is spec at 1600:1, my current SD LCD tv is 500:1 but it's several years old , all the TVs where displaying the same DVD , not a remote or instruction book in sight
 their computer said another store has 3 32" oliveas in stock, i called the store, they said they have ZERO the computer is WRONG
 guess i'm going store hopping tomorrow
	when looking around
 fry's has a large selection, but surpise the 27inch HD ready Olevia had NO video signal going to it,, OR it wouldn't detect it,
 found an office depot with the olevia 32" HDTV with the tuner thay had it plugged into the composite video signal from a small portable player
 everytime there was fast movement the picture was full of jaggies on the edges of the moving objects, i'm guessing it was feeding a de-interlaced signal, if not then the olevia is junk
 a couple more stops and back to the nearest office depot to look again at the viewsonic, it looks great, everything on display was showing the ame video feed the 'Incredibles' and the price has changed on the Viewsonic, its $549, after 50 instant rebate NO mailing IN..
 but i measured it and it's almost 3 inches too tall, it just won't fit because of the bottom mount speakers
 they had a 26 inch magnavox, but it just didn't have the same color and the black wasn't as deep, but it will fit my entertainment shelve,
 i'm on the look out for a sale of a 26/27 inch Viewsonic with the ASTC tuner
 if that 32 had fit my shelf, I'd be a proud owner right now
 FWIW, I didn't like the olevia menu system at all
 the Magnavox had the best menu system
 but the Viewsonic menus were reasonable, just NOT as detailed and easy as the magnavox
 but I buy for the picture NOT the menu system, Unless the thing is just to big a pita ( olevia )
	I have a 32" Monitor only version. 332H. Saw that they could be using LG panels. Like most of the reviews on their stuff. Really like it!
 Feeding it with a Samsung DTB-H260F HD Tuner, A Pioneer 220 and a Nintendo Wii.
 Most reviewer state they adjust some of the setting when they get it.
 Odd. The Frys where they had a 27 set up was not being feed anything. The CompUsless where I got mind at least was feeding via a Component...
 When you give it a decent data signal like Cars it really shines!
	nightwing
 thats nice too know, a guy i know who runs a AV electronics repair shop , said the olevias were good TV's, i ask him saturday..
 BUT when you go shopping you can only judge by what you see
 of course with HDTV beauty really is in the eye of the beholder, we can read all the specs and reviews, then we buy the most eye pleasing for the money we have, astehics really are a perception of mind & eye
	Consumer Reports had Viewsonic dead last for picture quality, apparently there is a reason they are so cheap. The Olevia and Vizio were pretty good for the low priced models.Originally Posted by theewizardI love children, girl children... about 16-40
 W.C. Fields
	most of the ones I looked at, have the ASTC hd tuner, only the 27 olevia at frys did not have a ASTC tunerOriginally Posted by zzyzzx
 funny Vewsonic, would be rate low, they have always been one of the best monitors around, and the TV with Tuner i was looking at , had the best picture in Office depot, and one of the best over at frys, where it had to compete with bigger TVs and plasmaOriginally Posted by ricoman
 the reds were red ( not red orange ) and the blacks were black the contrast was better than the TV with higher specs setting next to it
 I'm begining to think that 'for many mfg' contrast ratio is a statement of how many shades of grey the display has NOT the depth of difference between black and white in
 when a contrast ratio of 1000:1 has blacker blacks than a TV with 1600:1 or more and a brighter white and redder red
 there is something wrong with the listed specs
 what was consumer reports dislikes/problems
 do you have a link ?
	I have two 42inch Olevia and a 432 32 inch Olevia and let me tell you the picture quality is outstanding .Went to compusa to check the picture quality,better then some sets twice the price.Go for it.Just make sure it comes with internal tuners.My three sets do.
 Good luck
	Same reason I garbed the 32". Great picture!Originally Posted by MEL15
 When you pump a disk like Cars into it on a good machine it really shows how good it is.
 Also feed a first gen mac mini into it also does well.
	Different manufacturers measure contrast ratio in different manners. Generally whatever will give a particular monitor the highest rating. This usually includes showing a completely white image with the brightness up all the way (far beyond what you could normally use, a setting that would totally wash out the picture, to the point of damaging the monitor even) and calling the the brightest. Then they show a completely black image with the brightness turned as low as it will go (another completely unusable state), and call the all that the darkest. The contrast ratio is then the ratio of those two numbers.Originally Posted by theewizard
 If you want real contrast ratio numbers you need to find independent reports that use standardized and reasonable methods. Like using an ANSI standard black and white checkerboard pattern. Measuring this way gives much smaller ratios.
 http://en.wikipedia.org/wiki/Contrast_ratio#Methods_of_measurement
	jagabo, thanks for that info,
 the office depot down the street has the 32inch viewsonic and is out of stock on the olevia they are playing 'the incredibles on all the TVs from a video feed either s-video OR composite
 the one a few miles a way, has/had 3 olevia's but no viewsonics
 only had the (1) oli tv on display using the signal from a 6 inch portable player, the color was good but the motion was full of jaggies from bad interlace/de-interlace ?
 the
 check this one out . you may like it
 http://www.buy.com/retail/product.asp?sku=204042780&adid=17653&dcaid=17653
  Shopping for a bd driveBy johnestan in forum Blu-ray RippingReplies: 10Last Post: 14th Dec 2011, 14:55
  Is the feature Internet stream ready same as Wi-Fi ready on the Blu-ray DVDBy coody in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Nov 2010, 21:09
  Shopping for a CamcorderBy JJC in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2010, 10:46
  Shopping list for 2 setups? comments pleaseBy Dash1 in forum ComputerReplies: 1Last Post: 18th Apr 2008, 15:00
  Online shopping for AustraliansBy beavereater in forum Off topicReplies: 8Last Post: 3rd Aug 2007, 22:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
