    May 2006
    Canada
    I use TMPGne DVD Autor and TMPGne plus to make my dvd's, so far so good,
    but this time i wanna do it with 2 subtitles( English and French) which switchable like the original dvd
    is it possible? or any other way to do it?
    much apreciate if some one can tell me how, or even redirect me to some linked webpage or any hint..
    Apr 2004
    Miskatonic U
    Tmpgenc DVD Author doesn't support subtitles, so they would have to be added to the disc after authoring. It can be done, and there are several guides in the guides forum on how to do it using tools like PGCEdit and IFOEdit.
    Simpler would be to download the demo version of DVD Lab Pro, which will function for 30 days, and which does subtitles easily - up to 8 tracks.
    Read my blog here.
    Feb 2004
    Australia
    Simple stuff for rejig and pgcedit ... it's just what you want the menu to have that need's to be known .
    I can run a simple guide up for a single menu with 2 choice's , which would be basic .
    You'll just need to pm me if you would like a guide explaining the step's involved .
    May 2006
    Canada
    Thanks very much, now i have few leads to find out how to do it, , i will ask again if i run to trouble again, /bow
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    tmpgenc dvd author 3 has subtitle support now and a built in subtitle editor.
