Dear Forum
Using the above device here in UK, I employ the bundled blazevideo DVT (2) software to watch digital telly on the computer
Please does anyone know if this software is the only option available or is there any other programs free or otherwise that would do the same or similar job
Yours with thanks
Ian
ian c
Dear Sir
Thank you for these : please do you know if one can record subtitles also with any of these blaze video doesnt seem to be able to do this
Yours sincererly
(Ian)ian c -
I don't think any can record and add the subtitles permanent to the video. But they can record into a .ts (transport stream) and then you can extract the subtitle stream using for example projectx and then you can manually add the subtitle to the video...yes, tons of work...
Hi - thank you so much for sharing your knowledge. it is most helpful
Yours with thanks
Ianian c
recording 1080i from dvb-t usb tuner - best practices
By codemaster in forum DVB / IPTVReplies: 1Last Post: 15th Mar 2012, 03:10 -
Playstation 3 (PS3) as Dreambox replacement (using USB DVB-S)
By Dogoku in forum DVB / IPTVReplies: 0Last Post: 30th Jun 2009, 11:22 -
carbon coder usb dongle error
By sid_dionne in forum Video ConversionReplies: 9Last Post: 9th Apr 2009, 14:27 -
Cinergy HTC USB XS HD for DVB-C and SmartCard reader for Conax card
By XSIDE in forum DVB / IPTVReplies: 1Last Post: 12th Sep 2008, 13:08 -
Windows XP not recognizing USB DVB Tuner
By Bendit-like-Beckham in forum DVB / IPTVReplies: 4Last Post: 18th Nov 2007, 06:58
