I have produced a dvd using svcd2dvd but it is not recognised by the dvd player. Other dvds are full of vob inf and buf files. My dvd had just mpeg files. Is there a configuration file I need to alter to tell it to produce vob files? I have not seen any topics where the player would not recognise the disk at all.
Can you post your log? Did you burn your DVD manually or let SVCD2DVD burn it?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
There should be no mpgs on the final DVD.... As suggested - can you attach your log file? (Log files are kept in the "logs" folder under where you installed the program)
Samsung DVD P230 player gets confused
By ckmoore in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Mar 2012, 20:11 -
DVD player won't recognise hard drive
By Danny01boy in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2011, 22:43 -
Samsung HR775 DVD player
By akiskekridis in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Mar 2011, 10:03 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
Womble doesn't recognise avi audio from my Samsung Digimax
By keveen in forum AudioReplies: 2Last Post: 26th Jul 2007, 17:24
