I am a happy owner of a new LG DR1F9H recorder. I don't know how I ever got by with a vcr for so long now. Anyways, I was attempting to convert a video that I had recorded the other day and ran into a little problem. When a video is recorded to a dvdram disc, the files that are created are not typical dvd files. To rip the video to my computer, I use tmpgenc dvd creator which rips the video as a mpeg2 video(2 hrs in length). When I user total video converter(tvc) to convert the file to either xvid or divx, the output video scale is narrower and taller than the standard 4:3 aspect ratio. I adjusted the video settings of tvc but was unsuccessful in getting it right. Also, it takes tvc about 2 hours to encode this, is this right, because that seems just too long compared to what others have stated? Does anyone have any tips as to the video output settings and maybe what a decent time for conversion would be?
Tvc has 2 settings for the video output, one for the resolution and one for the apect ratio. Originally I left it at the setting for the same as the input file. I then tried changing the resolution to 640x480 and the aspect to 4:3 which did not fix the issue. When I used those same settings and converted to a different avi type(I believe h264), it seemed to be correct. I will try it again this evening and see if it does this again. What is the typical coversion rate/time though, I thought it would work much quicker than it does on my pc with all of the ram that I have installed.
AVI to MPEG2 Conversion Software
By cyberboy in forum Video ConversionReplies: 3Last Post: 7th May 2009, 20:54 -
DV-AVI conversion to mpeg2 or DVD
By obadvw in forum Video ConversionReplies: 6Last Post: 17th Apr 2009, 06:59 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 06:04 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 00:31 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 18:42
