Hello ppl,
I need some help in choosing a BT 848/878 based card...
I read Hauppauge Wintv Go and ATI TV Wonder are among them.....
Which is a better one???
Features are not important, its for some experimental purpose... so price is an issue... budget is arnd 50$.
Are there ne other brands?
Plsss help
Thanks in advance
Cheers
From your choices listed, I'd go with Hauppauge. The only thing I do not like about my Hauppauge is that I have to use their funky adapter to connect composite. But I've read countless stories about ATI using Macrovision, so that would be out in my book. Actually, the one I like best is the Pinnacle PCTV card. It has both composite and S-video connections, no funky adapters. All three have the same video quality as far as I can see. The all have the same bt878 chip in them.
Darryl
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 8th Oct 2011, 00:01 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
use 8x8 blocks with Sorenson H263 (FFMPEG)
By frifox in forum Video ConversionReplies: 1Last Post: 3rd Jun 2008, 13:58 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
