I have what I thought was a commercial DVD, but it turns out it is some funky DVD+RW according to DVD Decryptor. I've never ripped a full DVD before, but this is one of my alltime favorites from childhood.
Anyway, the DVD has been authored a bit weird, with two chapter 1s and so the program I would have used to convert it to XviD on the Mac is having difficulty reading both chapters that need converting. Thus, I thought I'd need to do the conversion on a PC. However, my PC laptop will not create or handle single files over 4GB. Luckily, the individual VOBs etc are all under that limit, but I was unable to run DVD Decryptor successfully. So my question is, since the DVD is not encrypted, do I need to rip the DVD to the HD first, or could I use AutoGK or a similar program by just pointing to the DVD as the input?
Hi-
If it's unencrypted, you can just drag and drop the files to the hard drive. You don't need DVD Decrypter at all. However, if DVD Decrypter couldn't do the job, perhaps there's something wrong with the DVD, scratched or dirty or something. As for AutoGK reading directly off of the DVD-ROM, I don't know for sure. You could try it, but keeping your DVD-ROM running for the whole encoding session is said not to be very good for the drive.
DVD Ripping to AVI (XViD + Lame) through MKV Magic. Is it possible? How?
By Bonie81 in forum DVD RippingReplies: 3Last Post: 17th Apr 2010, 10:05 -
Single 2+ hour DVD file ripping to individual XviD files
By perceptionist in forum DVD RippingReplies: 2Last Post: 16th Mar 2010, 04:40 -
Ripping from DVD into XviD / VidX, with subtitles
By p_uriel in forum DVD RippingReplies: 3Last Post: 10th Jun 2009, 08:50 -
Xvid to DVD conversion
By Meriks in forum Authoring (DVD)Replies: 5Last Post: 5th Apr 2008, 11:43 -
Is upconvert to 1080 really neccessary?
By ultrabigal in forum DVD & Blu-ray PlayersReplies: 8Last Post: 26th Nov 2007, 17:53
