hey guys i have a question. i bought a dvd recorder and ive been recording me playing madden so i can see what i did wrong . can any one suggest a free or in expensive program were i can record from different parts of the dvd. because i cant find one that works and is easy to use what im looking for is is like recording from 5 minute of playing to the ten minute mark because ive been searching and i cant find one. oh yeah may be you could suggest one that easy to use as well and im trying to make it so that the end product is an avi file beause i paln to put them on a dvd thanks
virtualdubmpeg2 is pretty easy to use and will let you output as avi.
mpeg2cut2 seems to be a pretty good, free mpeg2 editing tool, but only outputs the uncut portions of the stream, so you would still have to encode to avi afterwards.Read my blog here.
Hi!Originally Posted by guns1inger
I tried to convert/cut and MPEG2 file into avi with Virtualdub-MPEG2. I used direct stream copy, as I do with avi files, but I get an error notification which says that "MPEG2 files (the source video stream) uses a compression algorithm which is not compatible with avi files. Direct stream copy cannot be used with this video stream."
I'm a novice to this editing tool. Is there something else I should do? -
You must use VIdeo->Full processing if you want to convert to avi. Direct stream copy is to just copy the video and it's not posssible with mpeg2 in virtualdubmpeg2, use a mpeg2 editor instead then like mpg2cut2, videoredo.
Cropping Question
By darkdream787 in forum DVD RippingReplies: 25Last Post: 27th Oct 2011, 18:07 -
question about cropping
By dog food in forum EditingReplies: 5Last Post: 15th Oct 2010, 00:21 -
Question - Capturing to MPEG directly with VHS cropping
By joejoe in forum Capturing and VCRReplies: 2Last Post: 24th May 2009, 23:45 -
4:3 LBX DVD to Divx cropping question
By ecc in forum Video ConversionReplies: 3Last Post: 1st Oct 2008, 13:11 -
Cropping Question
By cowboysroy31 in forum EditingReplies: 2Last Post: 15th Aug 2007, 21:41
