I have a Magnavox MWR 20V6 VCR/DVD Recorder. I am new to it but have started to dump a few of my old videos to dvd (have to many videos). The instruction book does not say this, so hopefully someone can inform me.
- How long does a dvd-r record for while dubbing, as as the video or just 2 hrs?
- Is there a way of dvd recording from the vcr without dubbing, I want to pause the dvd recording and changes video tapes. Though my cable is hooked into the vcr/dvd recorder. Does this or does it not make a difference or what can I do.
You should have a speed/time setting for your recordings. The default "normal" setting is usually 2 hours. You should be able to increase/decrease the speed setting as need. The longer the recording time, the lower the quality. However, since the source is VHS, you should be able to get more than 2 hours without losing much if any quality.
As for your second question, I'm not sure what you are wanting to do. Any burning from the VCR source is dubbing, I don't know whether it will let you pause it or not.
Get a DVD-RW disc or two and experiment. That is the best way to learn and you won't be out any discs.Google is your Friend
VHS dubbing to DVD
By vegaspat in forum Newbie / General discussionsReplies: 11Last Post: 29th Mar 2009, 05:55 -
Tape to DVD Dubbing
By zambo in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2009, 14:00 -
VCR to DVD dubbing
By dcapp1 in forum Newbie / General discussionsReplies: 7Last Post: 20th Oct 2008, 14:53 -
Dubbing in audio to DVD
By jimlahey in forum AudioReplies: 1Last Post: 28th Jul 2008, 16:14 -
vhs to dvd dubbing
By zhavoronkova in forum DVD & Blu-ray RecordersReplies: 7Last Post: 22nd Jan 2008, 11:45
