so, i ripped a .vob file from a DVD, and, when i open it on VirtualDubMod 1.5.10.2 it displays the folowin message :
[!] MPEG: Anachronistic or discontinuous timestamp found in audio stream 29 at byte position 475488274, from 64194537 to 64259427. This may indicate an improper join.
when i rip the .wav file, i saw that it had a diferent length than the video file, which i have never seen before.
Does anyone know how to fix this problem ??
And, how can i "print" the subtutles that are in the .ifo file into the movie, usin vitualdub or any other program???
tanks a lot
Maybe try demuxing the VOB with, eg Rejig.
That should also allow you to get the subtitles, which are in the VOB, not the IFO.
You could also use DVDSubedit to extract, view and even OCR subtitles.
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 12:59 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
