I've used SVC2DVD to author and burn over 950 DVD's first using win98se, and later using winXP. It's the only DVD authoring program I've ever used that both works well and is fast and easy to use. It's been nearly 100% reliable.
I'm extremely frustrated that I can't get it to work at all on a new win98se PC that I just built. I have installed .net framwork 1.1 and sp 1 for .net 1.1, as well as .net framework 2.0. I also installed the VB runtime environment. I've changed the name of my C drive to be fully DOS compatable. All files are on the same drive as the program files, and is an IDE drive.When I try to add assets using the current V2.1 release, there is ffmpeg opens briefly, then shuts down. There is no log file created. All files I've attempted to add as assetts are 100% DVD compabable mpeg2. I just burned a perfect DVD using my XP machine with the same mpeg2 files that won't add as assetts.
I just tried using V1.5 for the first time, hoping that this might work. At least I can add assetts, but the DVD creation crashes. Program operates until it tries to resample audio from 44 to 48 KHz, while the originals are already 48 KHz, then crashes. At least I get a very lengthy log file explaining all the reasons it won't work. I get the error:
SVCD2DVD error.
Object reference not set to an instance of an object.
At_2b02761aea07325e.x210ff09a2516b1a7.xc4478098913 22395(String[]xce8d8c7e3c2c2426)
...consistantly for each mpeg2 assett. I do not really wish to use v1.5, since it is apparantly not compatable with DVD compliant files. I will paste the complete log file at the end of this message.
I later re-installed V2.1 current release, and it still will not allow me to add assetts.
I've also uninstalled that, and reinstalled V2.1.2308, which is the version that's worked so well on my XP box, and with that, when I click the "add assetts" tab, nothing happens at all. I don't even get a file dialog box to open.
There must be some missing dependancy. How else could this wonderful program work so well under XP media center 2005, and be totally non-functional with win98se? Please help Chris.
Starting SVCD2DVD: v1.51.2.0
Begin time: 8:20:54 AM
******** Ripping BIN images to get mpegs (VCDGear )
Analysing File: C:\My Documents\My Videos\movies\tv\Charleys Angels\dvd1\Angels In Paradise.mpg
++ WARN: unknown user data tag id 0x28 encountered
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: unknown private_data_id for private stream 1 seen (0x80)
++ WARN: mpeg stream contained no scan information (user) data
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
Error getting mpeg details. (probably due to AC-3 audio)
System.NullReferenceException: Object reference not set to an instance of an object.
at _2b02761aea07325e.x210ff09a2516b1a7.xb4e369192c57a f39(x2bc216f3ce925842 xa01d771a37e7320b)
Analysing File: C:\My Documents\My Videos\movies\tv\Charleys Angels\dvd1\Angels In Paradise 2.mpg
Analysing File: C:\My Documents\My Videos\movies\tv\Charleys Angels\dvd1\Harrigans Angel.mpg
Analysing File: C:\My Documents\My Videos\movies\tv\Charleys Angels\dvd1\Hula Angels.mpg
Analysing File: C:\My Documents\My Videos\movies\tv\Charleys Angels\dvd1\Island Angels.mpg
Analysing File: C:\My Documents\My Videos\movies\tv\Charleys Angels\dvd1\Waikiki Angels.mpg
-->Processing 6 mpeg files
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 720
Standard: NTSC
Audio SampleRate: 0
******** Demultipexing original mpg file
warning: couldn't find any valid system header. I'm continuing anyway
(Total size: 682MB, Duration: 00:02:08, Rate(MB/Min): 318.10)
******** Resampling audio from 44.1 KHz to 48 KHz
System.IO.FileNotFoundException: Could not find file "C:\My Documents\My Videos\movies\tv\Charleys Angels\dvd1\Angels In Paradise-0.mp2".
File name: "C:\My Documents\My Videos\movies\tv\Charleys Angels\dvd1\Angels In Paradise-0.mp2"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileInfo.get_Length()
at _2b02761aea07325e.x210ff09a2516b1a7.xfbd359f29063c 517(x2bc216f3ce925842 xa01d771a37e7320b)
at _2b02761aea07325e.x210ff09a2516b1a7.xf5d131c1b9f0e dc5()
How big are the files? For example Angels In Paradise.mpg ?
Those files are all about 685 MB, captured using variable bit rate MPEG2 at 1.8 mbps and Dolby AC-3 audio. I burned the exact same file set using SVCD2DVD on my XP machine with no problems. I also burned them using DVDAuthorgui with no problems as well. I would MUCH rather be using SVCD2DVD!!! I often mix resolutions, since I have a large collection of VCD and SVCD's.
Thanks for the attention,
Gealto2 -
Drag and Drop Assets
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th May 2011, 05:37 -
How do I move assets from one project to another?
By Anaheim in forum MacReplies: 1Last Post: 2nd Apr 2009, 00:14 -
DVD-Lab Pro Assets
By LabanB in forum Authoring (DVD)Replies: 5Last Post: 22nd Apr 2008, 11:01 -
Cannot add assets over network
By JohnRH in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 3rd Dec 2007, 23:57 -
Assets problem
By tandaman in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 7th Jul 2007, 19:25
