I'm converting a series of videos from dvd to XVID/avi, using AutoGK to encode.
I have auto width selected and set to 640. Since the source aspect ratio is 16x9, the resolution should be 640x360. Yet for some reason it turns out to be 640x368, and instead of being 1.78:1(16x9) its 1.74:1. Why does AutoGK do this? Anyone else notice this? Is there any way to override this? How about a way to change the aspect ratio without re-encoding the avi?
I tried turning off auto-crop in the AutoGK hidden settings. Still resulted in 640x368 avi.
asdf
Set it to use ITU resize and you will get 640x352 which is better than 640x368Originally Posted by iThinkYouBrokeIt
The reason it will not hit 360 exactly is due to mod 16 implementation.
What is mod 16 implementation?Originally Posted by FulciLives
And wouldnt 640x360 be the perfect resolution, since its perfectly 16:9? 640x352 is slightly less, and 640x368 is slightly more...asdf -
640x352 is mod 16 ... this means the height and width are evenly divisible by 16Originally Posted by iThinkYouBrokeIt
640/16 = 40
352/16 = 22
Also ITU will give you 640x352 whereas non ITU will give you 640x368. 640x368 is mod 16 as 368/16 = 23 but 640x352 will display better on a 16x9 WS TV than 640x368 and ITU is considered to be more "proper" anyways so ... there you go.
Why mod 16 you say? Has something to do with macroblocks and the way MPEG encoding works.
Youtube HD Resolutions
By bseos in forum Video Streaming DownloadingReplies: 12Last Post: 14th Oct 2011, 11:50 -
Capture resolutions?
By visionman in forum Capturing and VCRReplies: 6Last Post: 28th Jan 2009, 13:13 -
Strange AutoGK output files
By bennyboy371 in forum DVD RippingReplies: 7Last Post: 14th Mar 2008, 09:21 -
Question about resolutions
By ShinKyo in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 09:44 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 13:42
