I have an LG RH177 recorder connected to a JVC LT 32270SR TV using progressive scan.
I have a Sanyo VCR M2921R Video recorder that I was using previously to record material.
I'm trying to copy material from video tape to the recorder and from there will archive to DVD.
The VCR is connected to the AV2 input on the LG recorder via SCART.
When I select the AV2 source for record on the LG recorder I only get audio - no video is recorded.
I've tried using the other SCART connections on the LG recorder also with the same result and I have also tried different configuration settings for the AV2 input on the LG recorder.
Has anyone any ideas what the problem might be.
Any help would be very gratefully received.
Thanks,
Tim
Is the material on the VHS commerically recorded video or is it your own.
You may be being Macrovisioned. -
Probably not, because LG recorder would put a note on a screen "Uncopyable movie" and would not start to record.Originally Posted by oldandinthe way
I always use connections in front of the LG recorder (not scart) to connect a VCR. That should be AV4. Maybe you could try that. -
Is the scart input set to RGB or Composite? match the input and output settings. failing everything try a different scart lead
Thanks for all the suggestions.
I know I've tried different SCART inputs on the recorder and I've had AV2 configured as Auto, RGB and CVBS - all without success.
The only thing I haven't tried is the input on the front of the recorder (requires a SCART breakout lead). I'll give that a try and get back to you.
Thanks,
Tim -
Sorry for the delayed response. Just to close this one out - I went through all of the connections again at the weekend and presto!
suddenly it started to work.
I can only assume that one of the scart connectors wasn't seated properly initially (most likely the one on the video since I kept changing the others).
Thanks for your help.
Tim
recording test pattern on a vcr from PC
By mammo1789 in forum Capturing and VCRReplies: 11Last Post: 13th Apr 2012, 10:59 -
Recording in VCR Mode
By mapmaker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2008, 19:23 -
HDTV VCR recording, VHS TAPE?
By jb66 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 18:45 -
hatchetfish still a memeber ? lg rh177 help
By dante.7 in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2007, 18:32 -
LG RH177 region free disk
By Angof in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th Oct 2007, 06:04
