Hi
Im new here and just for the first time copied a family vhs tape onto DVD using a samgsung vr336 video recorder and DVD-RW disc. It is finalised in vr mode. I want to edit some of the video on my PC but dont know what i need to do it and the PC wont recognise the VOB format. Can anyone help?
Thanks![]()
JosephM
Try again using video mode and not VR mode. Standard video mode will create a disc that meets dvd specs (using video_ts folder and vob files) that can be read by other players and your pc.
Google is your Friend -
To get the video off the disk try VOB2MPG which will take the data from the VOBs on the DVD and create an MPEG file on the HD.
As far as I can tell there is no conversion done it simply makes the files pc readable (most likely it'll still be in MPEG2 format).
To edit - depending on what you want to do - have a look am MPEG-VCR by Womble. It will let you cut bits out (like adverts) and create a new file of just the bits you want to keep. It will also convert the audio from AC3 to MP2 if required. -
The problem is his pc can't read/doesn't recognize the dvd. This is because it was recorded using VR mode which doesn't use vob files.Originally Posted by IKnowNothingGoogle is your Friend
Thanks Guys
You ve been a great help. I got the video playing using the media setting in NERO video player and still screen capture shots were editable in Adobe photoshop for photos..have some great pics of my great gran!!
I used DVD decriptor on the VR format disk but it didnt work so ill re copy the video again and save it as v mode and use Womble and VOB 2mpg to get at the bits i want to delete.
thanks again
JosephM -
copy a vob to the hard drive, rename to change the ext to mpeg
now almost any program that edits mpegs can open it
'movie maker' comes with windows, it is already on your winXp pc
it's slow but it works,
you can also download a free 30 day fully functional ( not crippled ) version of 'movie maker 5' from ulead ( im testing it now ) I think MF4 is faster
MF5 will scan the disk and give a title and the number of chapters and you can import to the program and edit, then export mpeg files to authored as new dvd
using software like vob2meg is handy because it will cleanup little non-compliant glitches that renaming the file can't do
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Transferring video from a recorder for editing on Mac
By grhakl in forum MacReplies: 5Last Post: 30th Jul 2008, 10:38 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 05:54 -
Editing recorded material made by DVD recorder
By sallywil in forum EditingReplies: 2Last Post: 26th Aug 2007, 20:58 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
