I came across these at MacUpdate.com the other day. Anyone familiar with them?
http://www003.upp.so-net.ne.jp/mycometg3/
mp4vEncoder 0.6.3
libavcodec based QuickTime Media Compressor component. Support mp4v, MPEG-4 Video Media. Support some MPEG-4 ASP features, including B-frame with Open/Closed GOP. Source codes are included, and free software under GPL V2. Uses libavcodec.a and others from ffmpeg SVN-7945. (Universal Binary)
[Changes]
Support gamma and nclc. AltiVec/SSE2 yuv conversion. Fix preprocess, buffer alignment, and others. Sync core to ffmpeg SVN-7945.
[Tested env.]
MacOS X 10.4.8 + QuickTime 7.1.3
avc1Decoder 0.6.2+ (Last Update: 2007/02/04) (info)
libavcodec based QuickTime Media Decompressor component. Support avc1, MPEG-4 AVC/H.264 Video Media. This compoent overrides default Apple H.264 decoder compoent. Support some H.264 Main/Hi-Profile features. Source codes are included, and free software under GPL V2. Uses libavcodec.a and others from ffmpeg SVN-7752. (Universal Binary)
[Changes]
0.6.2+ One more fix.
0.6.2 Some minor fixes.
[Tested env.]
mp4vDecoder 0.6.2+
libavcodec based QuickTime Media Decompressor component. Support mp4v, MPEG-4 Video Media. This compoent overrides default Apple MPEG-4 decoder compoent. Support some MPEG-4 ASP features, including B-frame with Open/Closed GOP. And also supports PostProcess feature as De-block filter. Source codes are included, and free software under GPL V2. Uses libavcodec.a and others from ffmpeg SVN-7752. (Universal Binary)
[Changes]
[Tested env.]
mp4vDecoderDelegate 0.1.0
-EXPERIMENTAL- QuickTime Media decompressor component. Support mp4v, MPEG-4 Video Media. This DOES NOT INCLUDE any decompressor code, but it DELEGATES to Perian.compoent to decompress mp4v media data. In other word, this compoent overrides default Apple MPEG-4 decoder compoent. (Universal Binary)
[Changes]
Initial release.
[Tested env.]
Scallywag
Scally
#2 AND #3 look promising...will give them a try....."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Has anybody tried these yet?
Mark V
10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D -
I tried the AVC1 decoder. It comes with a preference pane for setting post processing.
I couldn't tell the difference from QT's AVC/H264 decoder so I removed the component... But I also never tried very hard.
--sdmvisit my photo retouching website: http://www.shiftstudio.ca -
I've started using mp4vEncoder. It's very good quality and its integration with Quicktime gives certain options compared to ffmpegX. It is very slow, though, on my Mac Pro, even distributing across four cores. There is no rate indicator, but it would be not much faster than real time, I don't think. I'll do some better guestimates.
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
Trying to update ffmpeg components
By doodlebuggy in forum ffmpegX general discussionReplies: 2Last Post: 20th Jul 2011, 21:57 -
Extracting the Y, U, and V components from a YUV source
By vhelp in forum Video ConversionReplies: 4Last Post: 23rd Jan 2010, 20:54 -
chinese drywall and electronic components
By kisrum in forum Off topicReplies: 8Last Post: 16th Oct 2009, 22:40 -
Ffmpegx missing codec components?
By plugues in forum ffmpegX general discussionReplies: 5Last Post: 10th Oct 2009, 11:51 -
Can not install mpeg components
By franks65 in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2008, 09:57
