Can someone please help me.
I have just installed a Conceptronics CTVFMi2 card into mt Dell Inspiron 5100 which has an onboard ADI sound card.
I need to get a cable to connect the s-video (9-pin din) to the audio in of the card (3.5mm jack plug). Does anyone know where I could source one?
Results 1 to 9 of 9
Why in the world would you want to connect a video cable (s-video) to an audio port? What do you hope to accomplish?
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
With 9 pins....audio might be included.
Losing one's sense of humor....
is nothing to laugh at. -
Good question, I wondered if s-video carried sound.
This is what I got when I mailed Conceptronic support....
Ls,
Have you made sure to use the 3,5mm jack that is on the AV cable and to
connect it to the line-in of your audio card?
Have you made sure to choose the line-in as source in your program
configuration?
With regards,
-----Original Message-----
Sent: zondag 4 februari 2007 14:00
To: support@conceptronic.net
Subject: CTVFMi2 soound problem.
Sirs,
I have just installed a CTVFMi2 card on my PC, it runs Windows XP and the
sound comes from USB speakers.
The TVR Plus software is working fine in all respects (Picture, remote
control, etc) except for the fact that I am getting no sound. This is not an
issue with the PC sound being mute, I get sound from other applications with
no problem, or the TVR Plus software set at mute. It currently displays
'Volume 100%'.
Can you help please?
The card has 4 ports...
FM (I assume the antenna)
TV (TV input - works fine)
S-Video In (Don't know)
Infa-red (Remote control)
http://www.conceptronic.net/site/desktopdefault.aspx?tabindex=359&tabid=360&mtid=194
Select the card then 'How to connect this product' to see what (little) details you get.
The instructions simply say "Connect the Audio-Out to the line-in of the sound card".
If the S-Video In doesn't carry the sound, what does? -
Are you recording from an S-video or composite source? If that's the case then you need to connect the source to the card via a stereo RCA to stereo mini pinplug cable:
http://www.amazon.com/HOSA-CMR206-Stereo-Mini-Y-Cable/dp/B000068O33/sr=8-4/qid=1171389456
Oops, sorry. What I thought was the audio input was an IR input.
The 9-pin DIN on that card is not a normal s-video input.
card:
s-video:
It probably requires a special pigtail with s-video and RCA inputs. -
The problem is not recording, it is getting any sound at all. All I want to do is watch TV on my PC.
The sound on my PC works fine. It has a built in sound card.(pictured)
I have been able to install and tune the TV with no problem. I'm just not getting sound with the TV picture. Somehow one of the ports on the TV card needs to be connected to one of the ports pictured. (I assume the black one). The question is how? -
Picture didn't seem to appear, it is on this link.
http://www.cnet.co.uk/i/c/rv/e/desktops/dell/dimension-5150c/story-1.jpg -
Many years ago I had a card with an internal tuner that required the audio be routed to a sound card -- like you are suggesting you need. It had a similar DIN connector and came with a pigtail cable with standard s-video output, RCA compostite output, and a stereo mini pin plug for audio output.
If your card required this it should have come with the cable. I suspect you just have a software issue and don't need a cable.
Originally Posted by brianc_li
external multimedia player advice sought.
By 22oakdene in forum Video Streaming DownloadingReplies: 0Last Post: 24th Jun 2009, 09:51 -
HD DVD patents sought by disc makers
By NICEBUD in forum Latest Video NewsReplies: 0Last Post: 27th Aug 2008, 02:58 -
ADVICE SOUGHT - RE-Editing DVD made from VHS
By Hal05154 in forum Authoring (DVD)Replies: 3Last Post: 22nd Mar 2008, 12:25 -
Recommendations sought for new laptop computer
By MJPollard in forum ComputerReplies: 4Last Post: 29th Sep 2007, 21:51 -
all region dvd player sought...help !!!!!
By CODEWERKX in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 16:07
