(Previously posted on the newbies forum)
Hi,
Got a copy of Movie Edit Pro (11 Plus) for Christmas.
I'm happy with the editing tools, and have used them to create several movies from stills (rather than restrict myself to the standard slideshow functions).
However, I have a problem with the DVD Menus produced. I am trying to put multiple movies onto one disk, and I don't really want a main menu, just a "chapter" menu with one icon for each of the movies I put on the disk. When I try to play the disk, I get the main manu with just one icon that starts playing from the beginning of movie 1. With some fiddling around (stopping, pressing menu button, pressing play in various combinations) I can get the menu I intended with one icon per movie. Overall, I have the BIG problem on playback that no icon in the menu is highlighted on the screen, and the arrow buttons on my remote do not highlight an icon. Hence I cannot navigate the menus at all.
Does anyone know of a fix for this?
Kindest regards
Dave
have you checked for auto start settings
on either the DVD authoring program or you DVD player
make sure thay are NOT set in the authoring program and the DVD player -
Checked - no such option in the package. DVD player doesn't have this set.
try convertX or download a fully functional trial of Movie Factory 5 from Ulead
these will give you menus for the different titles,
and MF5 will create chapeter markers and let you edit and cut the files before authoring
I have been using mf4 and just installed the trial version of MF5 -
Late reply, but I love my Movie Edit Pro 11 so I'm trying to help others (past or future) out.
I think what you want is:
1) On the Record tab import each movie as a NEW movie.
2) On the Burn tab make sure the "Menu adjust" section is visible (click the far left icon just above the menu preview) and select the "Movie menu only" Mode.
That should give you a single minu with one thumbnail for each movie which should go straight into playing the move.
Good luck!
Jon-Mikel
Magix Movie Edit Pro 17 - Help
By volotre in forum EditingReplies: 1Last Post: 12th Apr 2011, 11:27 -
Magix Movie Edit Pro 17 for .mts
By Buckskin in forum Video ConversionReplies: 0Last Post: 2nd Oct 2010, 14:51 -
Magix movie edit pro 15 burn problems
By wolfspirit1964 in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 17:10 -
Magix Movie Edit Pro and MP4's
By uihawks89 in forum EditingReplies: 2Last Post: 6th Jun 2008, 00:09 -
Magix Movie Edit Pro 11 Encoder
By SCDVD in forum EditingReplies: 0Last Post: 7th Jun 2007, 17:09
