http://pcadmin2005.free.fr/index.php?mod=3nityVideoConvert
I just found it and downloaded it, don't know how it stacks up against other tools that are available
'3nity video convert' it is NOT a dvd authoring tool
anybody else , ever use this tool
This software is not freeware, you will have to purchase a key.
Do unto others....with a vengeance! -
well that's a bummer, i didn't see anything on the website about it, did I miss it?
"Enter Key", "Buy Now!" Haven't you every seen these button when launch app?
Oh, my god. Are you the author? -
Before installing that program , you may wish to backup the system32 folder ... this crap will uninstall certain dll's , and one or more ocx file's that may actually be used by other program's which are not owned by this program , and could cause other video encoding / play back program's to fail .
Consider it "absolute junk" .
It say's "you should consider buying a key should you go past the evaluation period" .
1: Very trusting sort ... just keep using it but beware of what I said above .
2: It might include a time out feature , after which you need to buy a key . -
yes i have seen 'THOSE BUTTONS' on other crap ware, and quickly uninstall it and reset the registry
this is why i make restore points, run 'ERUNT' and use 'total uninstall'
BUT as i stated I didn't see anything on the webpage, and i HATE crapware and people that pull sneaky sh** like that.
it will NOT be getting installed on my machine
thanks for the warnings
simple freeware tool
By agent222 in forum Video ConversionReplies: 3Last Post: 1st Oct 2010, 16:22 -
Found freeware AAC to mp3 converter
By jimdagys in forum AudioReplies: 14Last Post: 22nd Aug 2010, 18:18 -
Splitting/Joining files: new Freeware tool!
By Anonymous5394 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2010, 16:38 -
Found an excellent freeware DVD copy tool...
By Djard in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2008, 20:17 -
is there a freeware tool for making an image of my c drive?
By surfmonkee in forum ComputerReplies: 17Last Post: 10th Nov 2007, 21:01
