I need some advice please.
I use Motion DV from Panasonic to capture and edit, then I use TMPGEnc Plus to encode and then GUI for DVD to author my DVDs. I have created many DVDs like this. Since yesterday this error message appears when I want to author the DVD.
Does anyone have an idea? Are there other authoring tools to use? Or is the problem with the initial recording or with my editing?
Sometimes mplex fails for 'unknown reasons' (or at least I don't understand why) with this error. It could be the output from tmpgenc, but I'm not sure. You can try to multiplex the files from tmpgenc with the ImagoMPEG-Muxer and use the resulting mpg file in GfD. Most times this helps. If the video is 100% DVD compliant (I can't see the video properties in the screenie), you can try the new development GfD version and use MuxMan as 'authoring engine'.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Dear Borax
I used ImagoMPEG-Muxer and it worked with the first try! Shoul on incorporate this always in your"chain" or when a problem arises.
Thanks -
As it is a rather rare error, I will not create a 'fail over automatism', but I will add the 'solution' to the FAQ.GUI for dvdauthor:
GUI for DVD Author settings problem vista 32
By extent in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2011, 18:24 -
Lookign for DVD Authoring with Flexible menu editing GUI
By zzerogg in forum Authoring (DVD)Replies: 2Last Post: 18th Jul 2011, 19:57 -
Little problem with DVD Slideshow GUI
By kippax in forum Newbie / General discussionsReplies: 8Last Post: 10th Jun 2011, 19:14 -
DVD slideshow GUI - problem with subtitles imported from exif
By jaceko in forum ProgrammingReplies: 10Last Post: 19th Jul 2009, 22:00 -
so many hours and than it donīt wonīt to work. DVD Slideshow GUI problem
By d.enz in forum Newbie / General discussionsReplies: 10Last Post: 5th Mar 2009, 12:49
