    Feb 2007
    I have a 4.37GB .iso fil that I want to burn to DVD so that it will play in a DVD player. Wen I try burning with nero, I get a message that says....
    "The entered block size does not correspond to the immage length. The block size may be wrong."
    HELP!
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    to burn ISO files use IMGBURN.
    http://www.imgburn.com/
    Feb 2007
    When I use ImgBurn I get this....
    "invalid or unsupported image file format"
  4. Something is wrong with the file,use IsoBuster (UDF) or Daemon Tools to extract.
    Dec 2006
    Here,where do you think?
    What you use to create your .iso file? usually IMGBurn is really reliable!!!!!
    " Who needs Google, my wife knows everything"
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    How did you create this ISO file ? Or is it a download ?
    If in doubt, Google it.
