  1. HI,,,,,
    I have a lot of Music Videos that I have tryed to burn with nero express, but when I put it in the dvd player it just shows the mpg files,,,,Is there anyway I can burn them so they auto play in the dvd,,,they are all converted to MPG files,,,
    All the MPG's are around 33mb to 70mb, So I'd like to have them all on dvd.
    any advice would be great
    cheers
    Apr 2004
    Miskatonic U
    If they are DVD compliant (see What is DVD - top left corner of this page) then you can author them with a half decent or better authoring tool, then burn them as a DVD.
    If you want to use Nero you need to use the NeroVision module to author them. As DVD authoring tools go, this is pretty close to the bottm of the heap IMO, as it will re-encode most DVD compliant footage given to it, whether it is required or not. This will simply lower the quality for no good reason.
    Read my blog here.
