I'm working in Pinnacle Studio 9.4.
The menu I'm using has 6 selection bars running along the left side of the screen from top to bottom and there is a next screen button at the lower right corner.
The problem is that when the menu comes up with the top selection bar highlighted, if I use the remote to move down I can get to the second bar, but another down command gets me to the next screen button instead of the third selection bar.
If I give a command to move up, I get to the sixth (bottom) selection bar and I can then move up to the top one bar at a time.
When I try to move down again, once again I can get to the second bar but another down command gets me to the next screen button again and I have to move up through the selection buttons from the bottom to get to the third selection bar.
The strange thing is that the second screen has three selection bars plus a previous screen button and this screen tabs perfectly.
I suppose there must be a way to get the tabbing order on the first screen to work they way I want, but I don't know how.
Any suggestions would be appreciated.
------------------ Bill
do I have a field order problem ?
By davexnet in forum Video ConversionReplies: 9Last Post: 13th Dec 2010, 13:41 -
What's the right way to fix a field order problem?
By brassplyer in forum EditingReplies: 13Last Post: 28th Dec 2009, 10:03 -
Problem with field order on captured video
By brassplyer in forum EditingReplies: 8Last Post: 3rd Apr 2009, 06:06 -
1. Field order problem? & 2. How to fix?
By fvisagie in forum Authoring (DVD)Replies: 29Last Post: 3rd Dec 2008, 20:31 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 09:19
