I keep getting the following error when trying to install the components on my MacBook Pro.
##sh: line 1: sudo: command not found
Does anyone have any suggestions? Thanks!
Results 1 to 9 of 9
Hi Regud
I'm not sure but it seems you must install the BSD subsystem on your Mac before to install ffmpegX and its components.
Have you got it on your Mac ?
http://videoandco.chez-alice.fr
I just created a new user account that is able to administer the computer, and was able to install the components under that login. It appears that I have changed some setting in my user account (also set to administer computer) that is preventing me from installing the components under my login. I know that I have set the root password so that I could configure the PATH for Ant and Java to compile my programs. Do you have any suggestions for checking my user settings?
Trying to update ffmpeg components
By doodlebuggy in forum ffmpegX general discussionReplies: 2Last Post: 20th Jul 2011, 21:57 -
What is windows installer for?
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2010, 13:51 -
windows installer?
By marcusden69 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Feb 2009, 07:36 -
Solved: Different computers, same components. Same performance?
By vid83 in forum ComputerReplies: 8Last Post: 14th Feb 2009, 19:12 -
Can not install mpeg components
By franks65 in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2008, 09:57
