    Oct 2006
    I'm thinking of getting tuneup utilities 2007, would that recover some of my memory. The reason why i'm asking this is because sometime ago i posted a thread regards low memory, at the time i had 192ram, i was told that was to low so i increased it to 640ram, things seem to be OK for a while when i was burning media, but now i seem to be getting the same error as before half way through burning so i was told that tuneup utilities will work, but i want to be sure before i buy.
  2. Member Soopafresh's Avatar
    Jan 2004
    Don't do it. Seriously. I doubt that's your problem.
    What's the error message you do get when you're halfway through burning?
    http://www.worldmag.com/images/content/5_carson.jpg
    Oct 2006
    I'll do another burn and post the log. Obviously it will take me 1 half to 2 hours, if you don't mind looking out for my post.
    Thanks.
  4. Member Soopafresh's Avatar
    Jan 2004
    Of course
    I'll bet something is loaded in the background, like a realtime virus checker or similar which is interrupting the burn.
    Oct 2006
    I've just done a burn and it's gone through no problem, i'll do a complete anti-virus and a anti-spyware as well just to be on the safe side.
    Thanks for you're help.
  6. Member Soopafresh's Avatar
    Jan 2004
    Cool. Keep your fingers crossed.
