  1. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    You see i Have this 7,72 GB Dvd but i wanna seperate it in 2 dvd's and keep the menus for both discs and i also want when the 1st disc is over a sign to come up "Please Insert Disc 2" Help please?
  2. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    Would that work on a seamless branching DVD?
    Nov 2004
    Las Vegas
    JConnor,
    If you're willing to give up the "Please Insert Disc 2" part, you can do it with VobBlanker, which is freeware. Here's a guide that shows you how to do it.
  4. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    Thanks for the info guys.
    Feb 2004
    Australia
    You don't have to give up anything ... only those with limited knowledge and sense of imagination need not apply .
    It can all be done using freeware .
  6. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    It worked for one Seamless branching DVD ( with DVDFab)
    But i have another double layer movie but I keep getting an error at the end "failed" Im not willing to give up the "Inser Disc 2" screen. Any other ideas?
    Nov 2004
    Las Vegas
    JConnor,
    If you don't want to give up the "Insert Disk 2", then the alternate freeware method would be this guide by 2COOL. It's (much) more involved, but should produce the result you're looking for. That guide also has a link to a selection of "Insert Disk..." packages to use with the guide.
    I've used VobBlanker many times to split a DL disk to two SL disks, but I've only used 2COOL's method once. It did work, but (at least for me) it wasn't worth all the extra work. At least it doesn't cost you anything (but your time) to give it a try.
