I have a short trailer (MPEG2) that has the following information (taken from GSpot).
Sys Bitrate: 6000 kb/s VBR
Video bitrate: 6997 kbps
Audio bitrate: 384 kb/s
I have the following questions:
A. How can I take a different video and achieve a similar result as above?
B. Is sys rate also referred to as mux rate?
C. Why is the audio rate in kb/s and video in kbps? Surely this would make the audio bigger than the video.
Thanks,
D
Results 1 to 1 of 1
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Black screen system32\DRIVERS\pci.sys Error with XP
By neworldman in forum ComputerReplies: 1Last Post: 8th Dec 2010, 16:34 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
BSOD STOP : 0x0000007E - tcpip.sys
By Jo The Veteran in forum ComputerReplies: 29Last Post: 28th Jul 2009, 03:38 -
Impossible installing XP on my compaq c571nr. iastor.sys?
By liquidsub in forum ComputerReplies: 2Last Post: 11th May 2008, 19:10
