Results 1 to 10 of 10
  1. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    I use Audacity on occasion, and have a couple of questions. I think I have a trial version. I see a counter somewhere that says I have xx hours of use left. I guess that means at some point, I will need to send some bucks to someone. Who? Is there a better description of the program than found with the download? When I try to grab video from winamp, I seem to end up with a much lower volume than winamp (and maybe WMP) produces. Any idea why that happens? It may happen when I finally xfer the output to a mp3 or other file format. Each time I start a recording over, I get new tracks pairs. So if I miscue, 3 times, the fourth set of track pairs is finally the good one. Is there a way to prevent new track pairs from appearing?
    Jan 2007
    That counter refers to how much more audio your hard drive is capable of storing. Audacity is open source & free. There isn't a trial version as it's not for sale. Good news, eh?
    Hopefully someone else can help you with the other thing.
  3. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    Thanks. Yes, good news, but that might mean the doc I see is all I get. It's pretty minimal.
  4. Mod Neophyte redwudz's Avatar
    USA
    There is quite a bit of documentation on their site: http://audacity.sourceforge.net/help/ There is also a new beta version of their software I am trying out.
    I don't know a lot about the program myself, I use it mostly for the filtering and to make dual channel audio from a single channel source. The newer version has added more filters.
    If you like their program, drop them an email. They always appreciate feedback and complements. I like to encourage freeware authors whenever possible.
  5. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    Ah, tutorials and new stuff. Great. Thanks. I wonder if I can edit a an audio file that has too much bass, and has some low volume scratchy noise on it? I guess I'll find out with the tuts. Yes, I'll contact them wit a thanks.
  6. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    Taking a look at the tutorials. I'm using 1.2.4. What's the version of the latest?* In 1.2, I don't see the use of the word filter. Perhaps it's in the later version. One thing I'd like to do is take a file that has too much bass and some low volume scratchiness in it, and boost the treble and eliminate the scratchiness.
    * Ah, it looks like a Beta version, 1.3.2. Not quite ready for prime time.
    Dec 2005
    /Hi,
    just added info... your not going to see specifically the word filter.. unless it the fft filter... otherwise there all under the effects menu...
    also audacity has a dedicated forum.... it fairly active....
    http://audacityteam.org/forum/
    now like previously mentioned there there help page does have alot of info there and you need to really go thru all the links... ie: the faq, tutorials, wiki, etc...
    in addition i found this one website and it had a nice overall tutorial on 1.2.6 that may or may not be usefull to you..... it consit of several webpages with graphics...
    http://www.guidesandtutorials.com/audacity-tutorial.html
  8. Member zoobie's Avatar
    Feb 2005
    Florida
    yes...make sure you're using the latest version 1.3...I tried doing something with an older version and it completely goofed up
  9. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    Go, Tigers!
