I have a HD movie in .TS it currently has a DD2.0 track muxed in, but I have a seperate DD5.1 (ac3) file I would like to mux into it. How would I go about doing this?
Nickolas
not very well at all -Originally Posted by Baldrick"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
ok for some streams --- but more often than not they will have many buffer over or underflows .... though not a huge deal for software playback (but a HUGE deal for broadcast) ....Originally Posted by Soopafresh"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Doesn't surprise me. Another way which I think might work pretty well would be to mux the audio and video into a regular MPG file, then load it in VideoRedo and save as a transport stream. Videoredo is one of the very few apps where I can convert from PS to TS and the resulting file actually plays on the MYHD hardware card in my PC.
Demux the transport stream with MpegStreamClip http://www.squared5.com/svideo/mpeg-streamclip-win.html
Command line mux via mplex.exe
mplex -f 3 -b 1786 -r 19200 -o output.mpg video.m2v audio1.ac3 audio2.ac3
mplex4hd.zip -
bbTOOLS is still also an excellent DEmultiplexor for transport streams ... what i still use a lot of the time because it works well with multiple audio streams in a TS stream ...
Yes indeed, and its an older app to boot... There's a version out there called bcdemux which is pretty fast and based on the same code.
Another great TS demuxer that deliberately tries to maintain A/V sync is Xport.exe
mux m2ts to m2ts with AC3 audio without reencoding the video
By BirdDaddie in forum Video ConversionReplies: 3Last Post: 22nd Aug 2010, 22:19 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
How to mux a AC3 file back into a mp4
By Scarpad in forum AudioReplies: 1Last Post: 26th Nov 2009, 11:44 -
mux 5.1 ac3 into wmvhd?
By nick101181 in forum AudioReplies: 5Last Post: 27th Jul 2008, 15:04 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 06:42
