I am planning on making a compilation DVD on a dual layer DVD made from several smaller DVDs (all are PAL). Since the sources are DVDs they are all ready in VOB format. I will be using Nero to create the compilation. I have done this before without problems where all sources were same aspect ratio, but this time three are in 16:9 and for two are in 4:3.
Can a DVD have content in different aspect ratios (for example titles 1-3 in 16:9 letterbox and 4+5 in 4:3) or does a DVD have to be purely one or the other?
Yes, you can mix different aspect ratios but you must create separate titles/tracks for each video and I don't think nerovision supports it. I use tmpgenc dvd author, click add track to create a new title for different aspect ratios.
Handbrake - ripping a DVD with various aspect ratios
By Ygramul in forum DVD RippingReplies: 1Last Post: 11th Aug 2011, 09:33 -
MPEG-1 on DVD with different aspect ratios
By DRP in forum Authoring (DVD)Replies: 8Last Post: 15th Aug 2010, 03:16 -
Joining Mixed Multi Angle Into Single VTS
By werdna1900 in forum Authoring (DVD)Replies: 1Last Post: 13th Jun 2009, 05:26 -
multiple aspect ratios on one DVD?
By towtruck in forum Authoring (DVD)Replies: 11Last Post: 7th Jul 2008, 03:58 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 16:13
