Results 1 to 11 of 11
  1. Hello, I have a problem that got me stuck for all last week!
    I would like to know if it exists any software that allow me to merge or join two different .flv files; the software must be usable by command line (no GUI) in order to be embedded in external application. I tried ffmpeg and mencoder but they didnt produce any playable .flv, or maybe i just dont know them well enough.
    I also would like to avoid re-convert .flv to other format before joining them and re-convert in flv.
    Thank you all!!
    I removed the request guide topic so moved your post here.
    How do you use ffmpeg? what commands?
    Macromedia Flash Proffesional I think can join but it wont be that easy to embedd...
  3. Hello Baldrink!
    Thank you for moving my post in the right place!
    I tried to use this:
    ffmpeg -i first.flv -i second.flv third.flv
    It just gives a flv with the content of the first.flv.
    I also tried to use in windows:
    copy /b first.flv + second.flv third.flv
    and then reencode third.flv with ffmpeg but the result is the same
    what syntax would you write using ffmpeg?
    Thanks again a lot!!!
  4. Member Soopafresh's Avatar
    Jan 2004
    Good luck. Unless all of the files have exactly the same resolution, bitrate, frame speed, etc, it won't work. You can try Mencoder
    Mencoder -o Output.flv -oac copy -ovc copy file1.flv file2.flv file3.flv
  5. Already tried, the result file just plays the first .flv (
    The files do have the same characteristics since I tried to concat the same file after giving it a different names. So it seems there's no solution....
    thanks anyway
  6. Member Soopafresh's Avatar
    Jan 2004
    ffmpeg -i file1.flv -vcodec rawvideo -acodec pcm_16le file1.avi
    ffmpeg -i file2.flv -vcodec rawvideo -acodec pcm_16le file2.avi
    mencoder -o output.avi -oac copy -ovc copy -noskip file1.avi file2.avi
    Then, encode the result back to flv
  7. I got this message Unknown audio codec 'pmc_16le' while converting to avi
    Seems like i have something missing, can I use some other codec?
  8. Thanks Soopafresh,
    at the end Ive been able to make the operation by using just mencoder! It makes the job in a unique command line since it is allowed to have more than one input file!
    Thank you!
  9. Movic-er
    Oct 2007
    flvjoin.exe that is shipped along with Movica should do the trick for you.
    http://movica.sourceforge.net
    Oct 2007
    Greece
    HELLO. I WILL SUPER WILL DO THE JOB FOR YOU.
