I have heard many people suggest that burning Cds (dvds aswell maybe?) at high speeds affect the quality.
Do they mean it affects the actual audio quality so it sounds worse or do they mean it affects the quality of playback i.e. it skips and stops etc??
Is this an eternal debate or is there a definate answer as to whether or not its true?
I just figured if the data is burnt to the disc, whats it matter how fast it burnt it?
Originally Posted by Rudyard
Not all media are created equal...not all burners are created equal.
Not all burning softwares are created equal.
Not all computer are created equal(polluted with hidden
processes running, malware, viruses etc etc).
Not all computer users are created equal(expect blazing
and accurate burning speeds while gaming, surfing video sites, downloading
huge files etc etc etc). -
CD's are digital, if all the information is successfully burned, the speed of the burn is irrelevant.
If the data isn't there it will skip. If there are data underruns due to speed being to fast for the system, it will skip or pop.
If you verify the burn you can find out if it completed correctly.
There is nothing to debate. -
Originally Posted by oldandinthe way
After checking some forums, it was advised that i reduced my burn speed, which i did, and burning the exact same file from pc to a CD, left me with a perfectly working disc.
The ONLY difference between the failed copy (3 times) and the working copy, was the fact that the working copy was burned at only 8x speed, not max.
I now ALWAYS burn at lower speeds, i've seen the proof. -
Was the disc burned and booted from the same drive?
If not then the problem may lie in the laser of the read drive. Like hech54 said, too many variables. That same max speed burned disc may read fine in other makes of readers.
A_L -
Once again ITS THE MEDIA!
Cheap media, you get what you pay for.
oldandinthe way, is correct ITS THE MEDIA! -
Originally Posted by Dr_Layne
Does packaging format of videos affect rendering quality?
By MarcMiller in forum Newbie / General discussionsReplies: 6Last Post: 1st Nov 2011, 16:27 -
Does using AviSynth affect quality?
By FrozenInferno in forum EditingReplies: 8Last Post: 27th Feb 2011, 11:41 -
relative quality and best burn speeds for some popular media
By JohnnyBob in forum MediaReplies: 32Last Post: 8th Feb 2008, 17:44 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Digital antenna v analogue antenna - does it affect quality?
By Rudyard in forum DVB / IPTVReplies: 14Last Post: 13th Sep 2007, 04:51
