Hello all,
Up till now I've been using this format to convert avi to dvd with no problem. However, I have some files that I can't convert because I'm getting this error message:
AVISource: couldn't locate a decompressor for fourcc xivd
I use avi2dvd and I don't think its the program because I can convert other avi files fine. Its just like 5 that have this error message.
I've downloaded the newest xvid already and it still isn't working. Any suggestions as now I'm totally clueless. Thank you.
If I have posted in the wrong topic please move this to the correct because I didn't see one for avi to dvd.
Have you installed any codec packs? Just asking because your problem sounds like a corrupted codec. You might try using Codec Sniper to look for and delete any damaged codecs. Also FFDShow might cause problems if you have it installed.
If all that fails, you might reinstall AVI2DVD. If you are still having problems, try ConvertXToDVD instead. -
I will try out these methods and see what results I get. However, it only occurs for like a few of my avis. I have no problem with the majority that I have. Also, these few that I have problems with were converted from rmvbs. Is it possible something happened during the conversion that I did?
Thank you for your replys, I always appreciate this forum because people acutally do reply back.
problems with converting TP to AVI using Auto GK
By KaNGaRooBaby in forum Video ConversionReplies: 0Last Post: 16th Aug 2011, 22:50 -
Problems with converting MKV to AVI
By Sayuri in forum Video ConversionReplies: 25Last Post: 1st May 2010, 07:57 -
Problems converting DVD to AVI, MP4
By azikiwee323 in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2009, 12:33 -
Problems converting Multiple .avi files w/ subtitles to DVD
By bwanis in forum MacReplies: 2Last Post: 30th Nov 2007, 13:23 -
Loads of problems converting avi etc. to dvd please help!!
By mrd2007 in forum Video ConversionReplies: 9Last Post: 14th Jul 2007, 12:53
