I own TMPGEnc xpress 3. Is upgrading to 4 really worth it? Will the mpg2 files be better quailty?
Trial it.
I did.
Quality is better. Not that you'd notice.
Main plus to upgrade is h.264 support with mainconcept (good) encoder, and divx support.
It is improved.
But if you strictly mpeg2 encode I don't think it's necessary. -
It all depends on what you want to do.
If you only need MPEG and you already have the AC3 plug-in, you you do not need to upgrade. -
Yeah I only need MPG. I shall stick with 3
Jagabo, please do not reply to this post. Thank you.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
