    Feb 2007
    Uruguay
    IŽm totally newbie so this questions may seem a little fool.
    I have a lot of VHSs that IŽll save in my hard drive as MPEG-2,
    donŽt think to make DVDs. Some of them will be edited and added
    transitions, titles and some video effects but the audio will
    remain unmodified. With others IŽll do the same but IŽll work
    with the audio too, deleting it in some cases, changing it by
    other music or narration background in others, and making noise
    reduction in others more. So here are the questions:
    1) In the cases where there will not be audio modification,
    which audio codec is the best to use in order for intense
    video editing doesnŽt affect audio quality: LPCM, Dolby
    Digital or MPEG-1 LayerII?
    2) And at the other side, with audio editing, the same question:
    which audio codec is the best?
    Thanks in advance.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    If quality is the issue, edit PCM (no recompression).
    NTSC DVD standard should be AC-3 or PCM although MP2 will play in most players (not standard).
    http://www.kiva.org/about
    Feb 2007
    Uruguay
    I forgot to say that here we have PAL-NC, however some VHSs I have are in NTSC so your answer is very useful.
    Thank you very much, edDV.
