i'm trying to toast (or even play...) a divx movie. (Mac OS 10.4.8)
it says the audio format is 'ms'
i searched and found some instructions to put the ac3 codec in /library/quicktime
but that didn't work.
is there a codec just for that audio format i can install?
Results 1 to 14 of 14
Borrow a pc and run gspot against the divx so you know for sure exactly which video and audio you have. There is some unplayable stuff still in OSX. There are many types of divx's.
I have ffusion and flip4mac components in that library as well. The QT player will handle almost any file that way. You can get flip4mac free here : http://www.flip4mac.com/wmv_download.htm -
Hey,
I'm new to mac and having the same problems with some avi's not having audio. I'm trying to burn to DVD using Toast Titanium 8.
I've downloaded the A52 Codec 1.7.2 as suggested and copied it to the appropriate folders but still no audio on Quicktime so I'm sure no audio when burned to DVD with Toast.
If anybody has any further suggestions (like is there an AC3 codec that I needed to download separately) please let me know.
Thanks in advance,
Steve -
Hi Ffooky,
Yes, I'm on an Intel Mac - brand new OSX 10.4.8 (if that makes any difference).
Thanks,
Steve -
Shot in the dark but check this Apple Discussions thread and see if Big Mike's solution does the trick.
edit: And you've restarted since installing the A52 component ? -
Hi ffooky,
No, I didn't thing to restart the computer after downloading the codecs so it worked.
Thanks for the help and advice.
Steve
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
No codec available when audio loaded in VirtualDUB
By Bucic in forum AudioReplies: 4Last Post: 27th Nov 2010, 17:13 -
Audio Codec after Synchronization
By Aurlito in forum Software PlayingReplies: 0Last Post: 13th Mar 2010, 10:47 -
VD Complain Audio Codec Not Installed
By ks47 in forum Newbie / General discussionsReplies: 2Last Post: 19th Oct 2007, 10:46 -
need mpeg audio codec?
By tomm2000 in forum Video ConversionReplies: 7Last Post: 7th Sep 2007, 20:34
